查看: 9829|回复: 1
运行turn_on_wheeltec_robot.launch文件出现问题??
发表于 2021-2-26 09:57:28 | 显示全部楼层 |阅读模式
运行turn_on_wheeltec_robot.launch文件出现resource not found:rplidar ros Ros path [0] =opt/ros/melodic/share/ros Ros path [1] =opt/ros/melodic/share/ the traceback for the exception was written to the log file
发表于 2021-2-26 09:59:22 | 显示全部楼层
首先进入正常镜像中的路径:/etc/udev/rules.d中复制70-snap.core.rules、558-orbbec-usb.rules、99-vmware-scsi-udev.rules这三个文件到相应目录下,然后执行: sudo service udev reload sudo service udev restart
GMT+8, 2025-5-9 23:31 , Processed in 0.064335 second(s), 25 queries .
