查看: 6079|回复: 2
process has died这是啥原因
发表于 2022-4-22 08:40:19 | 显示全部楼层 |阅读模式
运行turn_ on_ wheeLtec_robot.launch的时候process has died [ 9356, exit code-6, cmd / home/wheeLtec/wheeL  tec-robot/ devel/ / turn_ on_ wheeLtec-robot/ wheeltec-robot node name:  = wheeltec robot  Log:  = / home/ wheeLtec/ . ros/ Log/ e6ae27b8-cob8-11ec-b781-8a92cf8b72b5/ wheeltec robot-7  .1og]
发表于 2022-4-22 09:31:21 | 显示全部楼层
这个可能是因为串口号变了,比如你原来的A设备串口号是ttyUSB0,但你接入了B设备,此时B设备变成了ttyUSB0,程序读到了B设备的数据,所以节点挂了,建议创建串口别名,具体可以参考我们的wheeltec_udev.sh文件
GMT+8, 2025-5-11 09:01 , Processed in 0.080684 second(s), 25 queries .
