查看: 8012|回复: 2
无法打开串口
发表于 2023-6-6 22:19:37 | 显示全部楼层 |阅读模式
roslaunch turn_on_wheeltec_robot turn_on_wheeltec_robot.launch
报错:[ERROR] [1685772397.877180135]: wheeltec_robot can not open serial port,Please check the serial port cable!
按照常见bug.pdf的操作打开CP21xxCustomizationUtility.exe并安装了cp2102usb驱动/CP210xVCPInstaller_x64.exe。连接板子发现没有串口(点了refresh还是没有)
 楼主| 发表于 2023-6-6 22:22:23 | 显示全部楼层
输入:lsusb
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 8087:0a2b Intel Corp.
Bus 001 Device 006: ID 2bc5:0502
Bus 001 Device 005: ID 2bc5:0403
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 007: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 楼主| 发表于 2023-6-15 14:37:23 | 显示全部楼层
解决了,忘了把stm32和jetson连起来了。。。
GMT+8, 2025-5-10 07:55 , Processed in 0.119157 second(s), 25 queries .
