查看: 10962|回复: 3
web_video_server_ros2编译报错,有没有大佬遇到过
发表于 2024-5-14 08:26:30 | 显示全部楼层 |阅读模式
Starting >>> web_video_server
--- stderr: web_video_server
/home/cat/web_test/src/web_video_server-ros2/web_video_server-ros2/src/libav_streamer.cpp:12:63: error: use of enum ‘AVLockOp’ without previous declaration
   12 | static int ffmpeg_boost_mutex_lock_manager(void **mutex, enum AVLockOp op) // ffmpeg_boost_mutex_lock_manager的函数,它用于管理FFmpeg锁操作
/home/cat/web_test/src/web_video_server-ros2/web_video_server-ros2/src/libav_streamer.cpp: In function ‘int web_video_server::ffmpeg_boost_mutex_lock_manager(void**, int)’:
/home/cat/web_test/src/web_video_server-ros2/web_video_server-ros2/src/libav_streamer.cpp:19:10: error: ‘AV_LOCK_CREATE’ was not declared in this scope; did you mean ‘AV_LOG_TRACE’?
   19 |     case AV_LOCK_CREATE:
      |          AV_LOG_TRACE
/home/cat/web_test/src/web_video_server-ros2/web_video_server-ros2/src/libav_streamer.cpp:26:10: error: ‘AV_LOCK_OBTAIN’ was not declared in this scope
   26 |     case AV_LOCK_OBTAIN:
/home/cat/web_test/src/web_video_server-ros2/web_video_server-ros2/src/libav_streamer.cpp:32:10: error: ‘AV_LOCK_RELEASE’ was not declared in this scope
   32 |     case AV_LOCK_RELEASE:
/home/cat/web_test/src/web_video_server-ros2/web_video_server-ros2/src/libav_streamer.cpp:38:10: error: ‘AV_LOCK_DESTROY’ was not declared in this scope
   38 |     case AV_LOCK_DESTROY:
发表于 2024-5-15 11:12:07 | 显示全部楼层
这个的话可以试试用我们的镜像哈,自行配置的环境的话我们是不确保我们的源码可以在自行配置的环境上面正常工作的,需要自行排查和处理
 楼主| 发表于 2024-5-24 17:15:40 | 显示全部楼层
WHEELTEC-Until 发表于 2024-5-15 11:12
这个的话可以试试用我们的镜像哈,自行配置的环境的话我们是不确保我们的源码可以在自行配置的环境上面正常 ...
你们的镜像没有问题,
这是我自己装的镜像
发表于 2024-5-25 16:04:59 | 显示全部楼层
这个不太能判断出来问题呢,需要自行排查问题哈,我们不确保我们的源码可以在自行配置的环境里面可以正常编译且运行的
GMT+8, 2025-5-9 21:07 , Processed in 0.080838 second(s), 22 queries .
